Date/Time: Sun, 25 Oct 2026 00:30:23 +0000
eurex dax ger 30
View Count: 889
[2021-05-19 16:14:13]
bigwave - Posts: 1
why the given dax does not work, despite the fact that I pay for them?
[2021-05-19 16:29:19]
John - SC Support - Posts: 48317
You are not paying us for any real-time data. If you are having an issue with your data, then you would need to ask your data provider about it.
[2021-05-19 20:49:06]
Are you referring to the symbol GER30?
If so, refer to this help topic:
https://www.sierrachart.com/index.php?l=helpdetails3.html
Date Time Of Last Edit: 2021-05-19 20:50:47
[2021-05-21 17:54:44]
Sierra Chart - Max - Posts: 5984
From User:
still not wrok eurex for dax ger 30
Sierra Chart Support
[2021-05-24 14:48:46]
What is the exact symbol for which you are trying to get data?
