Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
Copy Global Graphic Setting to a particular Chart Graphic Settings
View Count: 2186
[2021-05-13 11:48:57]
User893396 - Posts: 40
All my SC is set up using the Global Graphic Settings for every charts.
I just want to make a few changes to some charts so I would like to copy my Global Graphic Settings to those charts, then uncheck use Global Settings and then make my changes.
How can I do this?
Thank you
[2021-05-13 14:44:53]
Sorry, but there is no support to do this. You just have to modify the Chart Graphics Settings to be the way you want.
[2021-05-13 15:15:18]
Would you consider adding this feature? Even if it requires to copy/rename/paste some files in SC directory there's no problem of course.
My Global Graphics Settings are fully customized and it would take really long time to copy by hand every single setting to the chart only to make 1 or 2 modifications, not to mention that maintaining later identical charts in my Chartbooks with only a few modifications on some will be much more easy it there's the possibility to transfer settings from global to particular chart.
IMHO that's a no brainer feature that SC should have.
[2021-05-13 15:22:05]
I just saw that there's a Save/Load Settings in the Global Setting dialog, just adding that same box to the Chart Graphic Setting would brilliantly solve the problem ! I am not a strong programmer but as the 2 dialog boxes for Global and Chart Settings seems to be the exact same that shouldn't be too hard to implement, isn't it?
[2021-05-13 15:41:20]
Nothing is ever as simple as it should be. But we do understand the request. Still, we can't say if/when we will be able to get to it.
Date Time Of Last Edit: 2021-05-13 15:41:32
[2021-10-20 17:05:26]
Trader & Sierra++ developer - Posts: 110
+1
Settings templates would be really great. I'm ready to help coding an external tool for this.
[2022-01-06 21:38:48]
User422433 - Posts: 18
+1
[2022-10-14 05:49:23]
Calinorth86 - Posts: 15
+1
[2022-12-21 14:18:00]
Hiroshigawa - Posts: 3
[2023-01-09 22:01:15]
User316362 - Posts: 215
+1
[2023-05-26 12:55:15]
User355952 - Posts: 1
Same!
[2025-09-12 19:26:25]
There is now the ability to copy to/from the Global Graphics for the Chart specific graphics. Refer to the following:
Graphics Settings: Copy to Global (Chart >> Graphics Settings >> Graphics Settings for Chart - Colors)
