Date/Time: Sat, 28 Nov 2026 11:53:57 +0000
acces plateforme
View Count: 884
| [2021-05-07 17:03:08] |
| samuel robatel - Posts: 4 |
bonjour, je viens de changer de code pour l'accès au login de votre site ! par contre, je n'arrive plus à accéder à la plateforme de trading j'aimerais bien prendre un abonnement mais j'aurai besoin d'accéder à la plateforme puis je savoir savoir quel est mon code pour la plateforme svp |
| [2021-05-07 17:44:30] |
From Google Translate: hello, I just changed the code to access your site login! on the other hand, I can no longer access the trading platform I would like to take
a subscription but I will need to access the platform can I know what is my code for the platform please Your Sierra Chart Account Name and Password are consistent between the website and the software. So if you changed your password on the website, then it also changes your password to login to your software. We do not know your password, it is stored encrypted, so no one can access it and tell you what it is. If you need to reset your password again, you can do so from this page: https://www.sierrachart.com/PasswordReset.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
