Date/Time: Sat, 28 Nov 2026 11:53:57 +0000
Windows error code 10053
View Count: 1922
| [2021-05-07 16:47:01] |
| User183724 - Posts: 194 |
This is a line from my log. Any idea why I keep getting this error? DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-05-07 11:29:57.519 * |
| [2021-05-07 17:17:09] |
It means that there is an issue with the connectivity of your computer. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
