Date/Time: Sat, 28 Nov 2026 11:53:57 +0000
Dupliquer un Chart et modifier le flux
View Count: 902
[2021-05-07 16:40:03]
User525038 - Posts: 14
Bonjour
je voudrais dupliquer un chart sur un autre chartbook et pouvoir changer le flux de façon a avoir deux flux différent, par exemple le Dax et sur l'autre chartbook le Buxel. Or j'ai toujours le même flux sur les deux chartbook, les deux change en même temps.
Cordialement
Daniel Defouilloux AC135732
[2021-05-07 17:10:06]
From Google Translate:
Hello
I would like to duplicate a chart on another chartbook and be able to change the flow so as to have two different flows, for example the Dax and on the other chartbook the Buxel. However, I still have the same flow on the two chartbooks, both change at the same time.
We assume that the issue you are having is how to change the symbol for a chart. Refer to the following:
Changing the Symbol of a Chart
