Date/Time: Sat, 28 Nov 2026 11:53:57 +0000
Volume Bars next to TPO - Need Help
View Count: 1888
[2021-05-06 21:50:47]
jujutrader - Posts: 7
Can anyone help me setup volume bars next to my TPO based on the example screenshot attached here.
I can compensate the person that can actually make this happen.
imageScreenshot 2021-05-06 143648.png / V - Attached On 2021-05-06 21:50:10 UTC - Size: 238.33 KB - 672 views
[2021-05-06 22:33:14]
Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles
It is hard to tell if there is something special about the image you provided apart from the above. If there is, let us know what it is and we can point you in the right direction.
[2021-05-06 22:42:11]
I need the day Volume bar and the current 30 minute period session volume bar to be visible on the left side of the TPO as seen in the screenshot provided. I have had tried already everything I could find including the link you provided but can't figure it out.
[2021-05-07 13:50:22]
You can have the Volume by Price profiles that match the TPOs next to each other. If you then want to have other VbPs for different time periods, those have to be on the right-side of the chart. There is no support to put them next to the TPOs. Refer to the following exmaple:
Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart
[2021-05-07 15:21:06]
How do I add the volume by price next to the TPO. I tried everything and can't figure it out. When I add the the VBP it just overlaps my TPO.
Looking into the support search it seems like a lot of people have the same problem and can't figure it out. Could someone please let us know exactly where in the settings to select what option?
Date Time Of Last Edit: 2021-05-07 15:21:59
[2021-05-07 15:24:51]
If you have the TPO study already on a chart, then just add the VbP and it will automatically be set to match the TPO and put the VbP to the right side of the TPO.
[2021-05-07 15:36:40]
I did but it doesn't add it to the right it overlaps on top of my TPO.
[2021-05-07 16:26:36]
Please attach a screenshot of what you are seeing. Refer to the following for how to take a screenshot:
