Date/Time: Tue, 10 Nov 2026 05:32:45 +0000
inaccurate MID
View Count: 843
| [2021-05-05 14:29:30] |
| User148596 - Posts: 217 |
Hi, I can't get my MID level to show up in the right spot. Any ideas what I'm doing wrong here?
| [2021-05-05 14:47:03] |
| John - SC Support - Posts: 48480 |
We need more information and a screenshot. In particular, the MID of what? and where it is showing and where do you expect it to be?
| [2021-05-05 14:55:19] |
http://www.sierrachart.com/image.php?Image=1620226271168.png RTH MID for F.US.EPM21 should be at 4165.50 but it's up at like 4169 |
| [2021-05-05 15:06:55] |
What study is that MID coming from? How is it calculated? And how are you determining where it should be? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-06 14:47:09] |
It's coming from the Daily OHLC study and when I do a price retracement from the HOD to the LOD the MID is not lining up with the 50% price retracement
| [2021-05-06 15:26:54] |
Attach the chart with the necessary studies on it. Remove any studies that are not needed. Refer to the following for how to attach a Chartbook with just the one chart in it: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-06 15:52:25] |
File attached
| [2021-05-06 16:04:03] |
You are currently using the "Average OHLC" to determine the MID. This does not give you the average of the high and low. If you want the middle of the High and Low, then you would need to use the "Average HL".
| [2021-05-06 18:08:47] |
okay great thanks for your help :)
