Date/Time: Fri, 03 May 2024 14:38:57 +0000
Data display at top of chart
View Count: 2649
[2021-05-24 16:04:19] |
John - SC Support - Posts: 31337 |
Sorry, I must have missed that post. The best way to do what you want would be to create a chart for each time period (1 day and 15 minutes), that way you have the cumulative volume for the time period of each bar. Then use one of the Moving Average studies based on the Volume. Note that the Volume is a subgraph of the Main Price Graph, so it is directly available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-24 20:12:22] |
User900676 - Posts: 57 |
Thanks John. You’re the best!
[2021-05-25 16:42:08] |
John how do I add a volume profile for rolling 365 years to the right margin of my TPO chart?
Private File |
[2021-05-25 17:17:05] |
Refer to the information here: Volume By Price Study: Single Volume Profiles At End of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-27 20:32:17] |
Hi John :) I always get a pause in my data feed at this time 16:30 ET (21:30 GMT my time). It is currently happening, my charts do not have a session break in them - i have split to evening a day session but I do not have any gaps... My connection status is Green - but price charts are not moving and nor is the DOM - this happens every day and last from around 21:25 my time for about 20/30 mins - it seems like it may be duye to the delayed feed I am using but still based on my chart settings there should still be a continuous feed? Can you think of a reason why this mgiht be happening? many thanks buddy :) S Date Time Of Last Edit: 2021-05-27 20:34:21
[2021-05-28 13:58:13] |
If this is the CME Group data, then it is due to the exchange hours. Refer to the Trading Hours for the ES for example on this page: https://www.cmegroup.com/trading/why-futures/welcome-to-e-mini-s-and-p-500-futures.html For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-28 14:02:32] |
Thanks John :)
[2021-06-01 18:59:08] |
Hey John, I paiud my excahnge fees yestreday and they seem to have expired already, can you help me out please buddy? :)
[2021-06-01 19:18:39] |
We see you added funds on 5/28/2021 to cover the cost of the Package renewal on 5/28/2021. But that left your account with zero balance, so when the exchange fee came due today, you did not have enough funds to cover the cost of the exchange. You need to add enough funds to your account for the exchange fee, and then you can reactivate the exchange at the bottom of this page: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices Note that you can view the transactions for your account at the following link: https://www.sierrachart.com/UserControlPanel.php?page=TransactionLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-01 20:26:30] |
THanks John, still getting the hang of all of the csots! :) much appreciated brother. You are the abolsute best!!!!
[2021-06-06 11:40:52] |
Hey John, hope you are well. also keep getting this error message when I try and set up a separate sub instance of Sierra: DTC Client socket (2) | Creating socket. | 2021-06-06 13:02:49.599 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-06 13:02:49.599 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-06-06 13:02:49.599 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-06 13:02:51.625 * DTC Client socket (2) | CloseSocket call. | 2021-06-06 13:02:51.625 DTC Client socket (0) | CloseSocket call. | 2021-06-06 13:02:51.625 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2021-06-06 13:02:51.625 DTC Client socket (2) | Closed. | 2021-06-06 13:02:51.625 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-06 13:02:51.625 Date Time Of Last Edit: 2021-06-06 12:07:04
[2021-06-06 21:03:25] |
Update Sierra Chart to the latest version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-06 21:26:42] |
many thanks!
[2021-06-08 19:12:55] |
Hi John, I have the issue exemplified in the attached image! I have a DOM running in a separate instance of sierra which seems to have a position open but I cannot get rid of it! |
2021-06-08 20_10_17-Footprint ESM21-CME [CBV][M] 5 Min #6.png / V - Attached On 2021-06-08 19:12:45 UTC - Size: 90.23 KB - 141 views |
[2021-06-08 19:21:45] |
I am not sure which situation is exactly what is happening, so try the following: 1. In the Sub-Instance, set Trade Simulation Mode to On/Enabled, then try to flatten the position. If that does NOT work, then do the following: 2a. In the main instance, set Trade Simulation Mode to On/Enabled. 2b. Go to the Trade Positions and see if the position is listed there. 2c. If it is, then try to flatten the position. 2d. Go back to the Sub-Instance and ensure that Trade Simulation Mode is Off/Disabled. 2e. Verify that the position is closed out. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-08 21:00:21] |
Hi John I tried this and it did not work - is there any way that the engeneers can go in and close it remotely?
[2021-06-08 21:34:57] |
It's a simulated trade, so there is nothing we can do remotely. You can always reset your simulated orders back to a default "null" state by selecting Trade >> Clear Trade Simulation Orders and Data. Refer to the following to understand that this will do: Trade Menu: Clear Trade Simulation Orders & Data (Trade menu) I assumed that you would not want to do that. Hence the ideas above and more below. If you go to the Main Instance, is that position showing? Or is it just in the Sub-Instance? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-08 21:43:16] |
Hi John, THanks for the suggestions however even after clearing trade ordeers it sstill remains! :S |
[2021-06-08 21:48:48] |
I need to know if that order is showing in just one instance (and which one) or both (the main instance and the sub-instance)?
[2021-06-08 22:08:12] |
just the sub instance
[2021-06-09 08:00:00] |
Hi John, this morning it has changed to several orders (not a position) in the subinstance. :S also getting this message when I switch from trading to sim account - but i do not have any orders open... Date Time Of Last Edit: 2021-06-09 12:15:34
2021-06-09 13_14_31-Window.png / V - Attached On 2021-06-09 12:15:30 UTC - Size: 20.96 KB - 142 views |
[2021-06-09 14:00:17] |
What I am trying to understand first, is whether this order was put in when the Sub-Instance was in Simulation Mode or not. It can get confusing, as the Main Instance may be in Simulation Mode, but the Sub-Instance is not, so the Sub-Instance sees the order as a non-simulated order, but the main instance is seeing it as a simulated order. Also, it may mean that you have to remove the Order Fill in the Main Instance and not in the Sub-Instance. When you find the fill let me know if it is a Simulated symbol or not. You may have to switch between the options for the symbols between the Simulated and Non-Simulated to find it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-09 15:12:40] |
how do i find the fill? sorry for being ignorant! :D
[2021-06-09 15:30:38] |
Open the Trade Activity Log and set the Activity Filter to Fills, then select the "Apply" button to update the information in the Trade Activity Log. Refer to the following for information on how to use the filter options at the top of the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Note that you will want to work with the Symbols filter as well to find the right item as to whether it was a Simulated or Non-Simulated order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-09 15:51:44] |
this is what i can see :S
2021-06-09 16_51_15-Window.png / V - Attached On 2021-06-09 15:51:35 UTC - Size: 70.97 KB - 246 views |
