Date/Time: Sun, 05 May 2024 01:07:42 +0000
Is the Rithmic Direct-DTC currently working at the moment?
View Count: 3111
[2021-06-01 19:21:12] |
User158665 - Posts: 44 |
Is "Rithmic Direct-DTC" working? How to set it up if it is working and is it better than Service "Rithmic Trading" (I would like to use it with UProfit).
[2021-06-01 20:29:40] |
John - SC Support - Posts: 31362 |
It still has not been released by Rithmic.
[2021-06-01 22:41:36] |
Ticks - Posts: 174 |
@User158665 . I`m currently using SC to connect to Rithmic for UProfit evaluation. SC isn't listed as a supported platform on their site, but if you send them a support ticket asking to use SC they will give the ok to use it. |
[2021-06-01 22:47:05] |
SabikiSensei - Posts: 74 |
@ticks Let me know if you find a way to connect the live credentials (when you get the account funded at UPT) I had been using ninja dom for execution and its been very cumbersome |
[2021-06-01 22:55:02] |
I don't think there should be any issues between the live and eval. I didn't have any issues connecting SC to Rithmic. I`m using SC version 2258. Just set your Data/Trade setting in SC. Select "Rithmic Trading" Server List"Paper Trading Server" Username:Your UProfit username Password:Rithmic login password UProfit was running a 40% lifetime discount last month on all their funding levels. So I could not wait any longer for Rithmic to provide an updated version. Took a chance and data connections is working good so far. Date Time Of Last Edit: 2021-06-01 23:04:28
[2021-06-01 23:34:00] |
@ticks the problem is that when you need to connect your live credentials, it will need to be through the Rithmic - Uprofit portal. Which is not an option even under Rithmic Trading. |
[2021-06-01 23:53:32] |
SabikiSensei Ahh, ok. Hopefully, the new "Rithmic Direct-DTC" will be ready soon. Date Time Of Last Edit: 2021-06-01 23:55:14
[2021-06-24 21:13:26] |
ivory - Posts: 77 |
Is this new connectivity option with Rithmic based on their API Platform (Web Sockets)?
[2021-06-24 22:47:29] |
SC has posted an update here in regard to Rithmic. Date Time Of Last Edit: 2021-06-24 22:48:09
[2021-06-28 04:51:37] |
User311677 - Posts: 16 |
Are we able to connect 2 platforms, like Sierra and Bookmap? Or this is not supported? |
[2021-06-28 06:07:28] |
Sierra_Chart Engineering - Posts: 14224 |
Here is the updated documentation to connect Sierra Chart with Rithmic: Rithmic Trading Platform Service Whether more than one connection is allowed, we do not think this is the case now. Since the connection is direct to the Rithmic server and not through the R-Trader software. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-11 21:11:01] |
ejtrader - Posts: 688 |
SC Team - When SC is connected through DTC protocol(new) - it would disconnect the R-Trader software. Other software would connect through R-Trader using bridge mode. Would there be a change in the future to allow the connection through R-Trader?
