Date/Time: Sat, 31 Oct 2026 04:18:42 +0000
TAL rounding some trades to tick value, some not.
View Count: 1045
[2021-04-30 19:04:13]
j4ytr4der_ - Posts: 947
My Trade Activity Log P&L reports always display single ES ticks rounded out to 13. So a 1 tick win or loss is +/- $13. Some larger trades clearly round to increments of 12.50 ($50, $75, etc.) but others absolutely do not ($38, $63, $113, etc.). Some are 1 lots, some are multiple lots, I don't see a consistent pattern there. Commissions are not in use and shouldn't be a factor. Symbol settings are set correctly, Chart Settings tick value is set correctly.
Is there some setting somewhere that could do this?
[2021-04-30 19:07:34]
Can you show us an example of what you are seeing?
And what is your Currency Value per Tick set to on the chart where you are seeing the issue?
[2021-04-30 19:25:56]
Sure thing,
https://snipboard.io/SWrZ2C.jpg
Currency value per tick is set at 12.50 for every chart. Also I'm seeing this in the TAL, not a specific chart.
[2021-04-30 20:11:51]
Check what you have entered for the following setting:
Global Trade Settings Windows: Number Decimal Places for Displayed Currency Value (Global Settings >> General Trade Settings >> General)
Most likely this is set to 0. It should be 2 to show 2 decimal places (i.e. 12.50 instead of 13).
[2021-04-30 20:14:27]
WOW that was it. I have never touched that setting, no idea why it would ever have been at zero. This has plagued me from the start of my time with SC. Thank you!!!
