Date/Time: Sun, 01 Nov 2026 05:19:54 +0000
hI IM TRYING TO CHANGE MY TIMEZONE
View Count: 1005
| [2021-04-29 16:09:50] |
| User750124 - Posts: 1 |
hI IM TRYING TO CHANGE MY TIMEZONE CLICKING THE > DATA/TRADE SERVICE SETTINGS TAB, i KEEP GETTING THIS ERROR MESSAGE *Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2021-04-29 08:51:04.223 * i WANT TO CHANGE IT SO ITS SET FOR NEW YORK TIMEZONE.
| [2021-04-29 16:49:02] |
| John - SC Support - Posts: 48377 |
You are dealing with two different items. First, to change the Global Time Zone, you need to select Global Settings >> Time Zone Settings. You will change the Time Zone there. The error message you are getting is related to the option Global Settings >> Set System Date Time from Server or the setting for Global Settings >> General Settings >> Periodically Set System Date Time from Server. Your Sierra Chart software does not have Administrative privileges to change your system clock. Refer to the following: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
