Date/Time: Sat, 31 Oct 2026 06:11:03 +0000
Change affiliation in my account
View Count: 788
[2021-04-15 18:23:00]
User370729 - Posts: 4
How do i change my account affiliation, my account is Infinity Futures and i want to switch to my AMP account, what procedure should i do to make this exchange?
[2021-04-15 18:36:57]
We notice that the affiliation for your account has already been cleared. Although that item did not have any impact at this time.
So you are fine to use your current account with any broker. There are no restrictions.
[2021-04-15 19:15:31]
Where can i setup my AMP account on the "account painel", to put my information from my amp account, and things like that.
[2021-04-15 20:11:32]
You do not need to do anything with your Account Control Panel related to AMP.
When you get setup with AMP, you will most likely be setup to use CQG for your order routing. As such, once you get your CQG credentials, then you will follow the Setup Instructions at the following link to setup your Sierra Chart software to connect to CQG:
CQG Trading Platform Service: Setup Instructions
Once you finish the above, then open your Chartbooks and select Edit >> Translate Symbols to Current Service to change your symbols to CQG symbols.
Then that is it. You will be all set to trade using your AMP account.
