Date/Time: Sun, 15 Nov 2026 04:57:05 +0000
Trade Activity Log
View Count: 963
[2021-04-14 06:10:21]
DayTraderEsad - Posts: 121
I ran the report several times on the Trade Activity log "Trades" tab and "Statistics" and it is showing that there were short trades for today 4/13 (entered today and exited today). I did not make any short trades, all of them should be long. Can you please check on that? Thank you for your help.
imageCapture.PNG / V - Attached On 2021-04-14 06:09:37 UTC - Size: 73.35 KB - 401 views
[2021-04-14 15:07:28]
This most likely is because the starting Date-Time is not correct. Refer to:
Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List
Otherwise there could be a missing fill. In this case refer to:
Trade Activity Log: Automatically Inserting Missing Order Fills
[2021-04-15 17:01:10]
I ran the report for the day off, and it is still showing short when I am only doing long. Specific symbol for this is MNQ. Its not missing fill from what I see, it just not coding it correctly. Should be long trades.
[2021-04-15 17:16:24]
I figured it out, I was running the TradeActivity Log on Instance #2 for the day and it showed all short trade for the day when it was all long. Then I ran it from the main Sierra dekstop - it gave the correct statistics for the day.
[2021-04-16 14:26:15]
Still the information we gave in post #3 would be applicable to a sub instance. The data should show there correctly as well.
