Date/Time: Sat, 31 Oct 2026 06:10:43 +0000
[Programming Help] - DRAWSTYLE_TEXT - Left or Right text alignment instead of default Center
View Count: 5983
| [2021-04-13 04:22:09] |
| Dema - Posts: 42 |
Hi Team, I have coded an ACSIL study to use the DRAWSTYLE_TRANSPARENT_TEXT / DRAWSTYLE_TEXT to plot words when conditions are met. The default text alignment appears to be centered, but I need to be able to make this left-aligned and/or right-aligned because it is too hard to see which bar the text relates to. Can you please help with how I can do this? I tried the below from tool text alignment but that didn't work ('struct s_SCSubgraph_260' has no member named 'TextAlignment') Using Drawing Tools From an Advanced Custom Study: s_UseTool::TextAlignment Thankyou |
| [2021-04-15 03:37:42] |
| Dema - Posts: 42 |
Hi SC Team, Can you please reconsider this as a support ticket, not programming help? Reason being that ACSIL doesn't appear to support text alignment functionality for DRAWSTYLE_TEXT. If this is true, please consider it a feature request, else please advise if there is undocumented functionality to do this. Thankyou Date Time Of Last Edit: 2021-04-18 22:48:47
