Date/Time: Sun, 08 Nov 2026 00:35:06 +0000
VbP Chart Causing Very High Power Useage, Low CPU useage
View Count: 1051
[2021-04-06 13:19:30]
HeidiT - Posts: 16
I have a VbP chart that I would like to keep. It computes multiple time frames.
Is there a way to stop it from manually recalculating the studies. I don't mind updating it every half hour or so myself.
When I remove the chart from the chartbook my Power usage for SC goes back to very low, I know it is this one chart that is causing issues.
My CPU use is fine and usually around 5% no matter how many charts I have open.
The power usage is high whenever I add the VbP.
I was thinking that if I could stop it from calculating the studies and just calculate them intermittently, this would solve my problem.
Does anyone have any advice?
Again, I would like to keep the study and be able to see it while trading.
Thank You
Heidi
[2021-04-06 21:23:35]
Provide this chart by following these instructions:
[2021-04-06 22:11:55]
HeidiT - Posts: 16
Here is the chart.
Thank You!
Private File
[2021-08-19 19:01:09]
This had gotten overlooked. Some of the Volume by Price studies are configured very inefficiently. For example, this Input setting:
Volume By Price Study: Time Period Length for 'Fixed Time'
Needs to be increased. In one case it is set to 1 minute. That is way too low based upon the amount of data loaded in the chart.
