Date/Time: Mon, 28 Sep 2026 14:41:45 +0000
Quick Question About AMP ? Data Feeds
View Count: 753
| [2021-04-01 15:50:00] |
| User175324 - Posts: 3 |
I wanted to know is it still possible to execute live trades with SC and AMP Futures? Or is the affiliation completely terminated? Thanks for answering the questions. Looking to see what do with my account. |
| [2021-04-01 17:46:08] |
| John - SC Support - Posts: 48029 |
AMP stopped support for the Sierra Chart Order Routing Service, that was all. We both still support the use of CQG, so that service can be used with AMP for your order routing with Sierra Chart. AMP should have automatically moved you to CQG when they stopped the service for the Sierra Chart Order Routing and sent you the information for your CQG account. If you do not have this information, then check with AMP. Once you have it, you can then setup your Sierra Chart to connect to CQG by following these instructions: CQG Trading Platform Service: Setup Instructions Once you complete the above, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will change your symbols to CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
