Date/Time: Tue, 06 Oct 2026 09:56:22 +0000
Message Log says 'The Chartbook file is not a valid Chartbook File
View Count: 1298
[2021-03-31 16:05:42]
David Clarke - Posts: 23
For the last 2-years I have accessed Sierra Charts through the broker software of TransActMA (Infinity).
Yesterday (30th) I started a direct subscription with Sierra Charts (no longer through TransActMA).
Having successfully logged into the Sierra platform, I now want to access some of the (many!) Chartbooks that I created in the past. However, when I follow the standard Open Chartbook process: File / Open Chartbook, and select a Chart and click 'Open', I get a message (in the Message Log) telling me that 'The Chartbook file is not a valid Chartbook File: C\SierraChart\SierraChartTransActMA\Data\Chartbook MAR07 SF
How do I resolve this?
Date Time Of Last Edit: 2021-03-31 16:08:25
[2021-03-31 18:48:10]
Attach the Chartbook file here so we can test. Instructions:
You also have access to backup Chartbooks:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2021-03-31 20:14:16]
As requested, files uploaded
These Chartbooks (files) are just two of many (Chartbooks) that I would like to be able to access
[2021-03-31 20:30:38]
John - SC Support - Posts: 48114
There are no files attached. Please try again.
[2021-03-31 20:52:14]
Sorry about that
These (attached) are two of many files (Chartbooks) that I would like to access
attachmentChartbook MAR25 - 8MA Colour ADX.Cht - Attached On 2021-03-31 20:51:11 UTC - Size: 146.31 KB - 442 views
attachmentChartbook MAR22 - SF on 8MA, ignore ADX.Cht - Attached On 2021-03-31 20:51:51 UTC - Size: 141.83 KB - 355 views
[2021-03-31 22:08:23]
We tested one of your Chartbooks and it opens just fine:
Try opening it again through File >> Open Chartbook. You should not have any problems.
[2021-04-01 08:44:37]
Nope, that did not work. Unfortunately, I get exactly the same message - 'The Chartbook file is not a valid Chartbook file'.
I am no techie, but I don't think the problem lies with the file itself.
I think the problem is the folder (in the C:Drive) in which it sits. Namely C\SierraChart\SierraChartTransActAM\Data\Chartbook MAR 25 - SF on 8AM, ignore ADX.Cht'
I suspect the \SierraChartTransActAM\ element of the file name is the issue. Could this be the reason? If so, how could I resolve this?
[2021-04-01 17:06:11]
Go to File >> Open Chartbook. Do you see that Chartbook file listed there?
No this is not a problem:
[2021-04-03 11:55:12]
I am afraid it was a problem, but it is a problem now resolved with the help of my broker's (TransAct / Infinity) support team.
Anyway, thanks for taking a look at this.
For clarity, this issue is now resolved.
[2021-04-05 13:56:19]
That does not make sense to us. What the actual problem was is not clear to us but if it is resolved that is good.
