Date/Time: Thu, 29 Oct 2026 16:59:35 +0000
Chart Trading Order Lines
View Count: 1171
| [2021-03-23 16:49:08] |
| User499894 - Posts: 67 |
Hi is it possible (while in chart trading mode) to display Order Lines underneath candles/bars? |
| [2021-03-23 17:32:13] |
| John - SC Support - Posts: 48366 |
There is no support for this. But, you can align the order to the right side of the screen so the lines are not overlapping the bars at all. Refer to the following: Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
