Date/Time: Tue, 27 Oct 2026 14:55:00 +0000
Discrepancy between VWAP
View Count: 993
| [2021-03-23 13:21:36] |
| User837393 - Posts: 161 |
Hello, Why do I see see decrepency between VWAP (Rolling) in 1 min vs VWAP (Rolling) 2.00 Range ? Settings and inputs are the same ... Best regards, |
| [2021-03-23 13:28:04] |
Solved... I had settngs wrong... one was in deviation mode and the other one in variance.
| [2021-03-23 13:37:08] |
Sorry I spoke too fast. The issue is still there ... there is a point of difference between VWAPS. http://www.sierrachart.com/image.php?Image=1616506720662.png Vs http://www.sierrachart.com/image.php?Image=1616506743384.png Date Time Of Last Edit: 2021-03-23 13:39:10
| [2021-03-23 15:01:32] |
| John - SC Support - Posts: 48340 |
Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Differences Between VWAP and Standard Deviation Lines On Different Timeframe Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-23 15:20:35] |
Unfortunately there still ia a discrepancy. Global trade settings is set to : 1 Tick Base on Underlying data is set to : Yes |
| [2021-03-23 15:26:03] |
Yes that is expected. And the documentation linked at post #4 has been updated.
