Date/Time: Thu, 29 Oct 2026 17:00:26 +0000
The same problem with SC every single update!!!
View Count: 976
[2021-03-22 16:29:44]
User674409 - Posts: 26
Im really tired that every update I have the same problems with you. I need to work with Sierra chart version 2168. Now I can't because you dont give anymore support. I need that version because is the only one thats works properly on my laptop. So please make something so I can run it again.
[2021-03-23 17:08:38]
We apologize for the delay with our response. We see you are using CQG, and you really need to be up-to-date With Sierra Chart when using CQG. We cannot allow version 2168. It is an older version, which has issues working properly with CQG in regards to historical data.
Tell us what the problem you are having is and we will help you. You should not have any problem running Sierra Chart on your computer.
