Date/Time: Fri, 18 Sep 2026 17:31:06 +0000
Problems with Extended Line Configuration Defaults
View Count: 1245
| [2014-03-03 17:57:33] |
The lines look correct. The extended line 1, is intersecting with the bottom edge of the Region Data Line at the top of the chart and is getting clipped. That is completely normal. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
