Date/Time: Fri, 09 Oct 2026 05:22:19 +0000
[User Discussion] - Most Accurate Tick by Tick testing
View Count: 925
| [2021-03-13 21:38:39] |
| deezee - Posts: 5 |
Hi, I would like to know the most realistic way of backtesting market replay. I've tried the Accurate Trading System Back Test Mode and used the Jump Method of by Number of Trades to 1 - I assume this is 1 tick, with the highest speed setting of 30720. Would this be the most realistic way of backtesting? Thank you! |
| [2021-03-14 01:54:15] |
| Flipper_2 - Posts: 57 |
The jump setting are for jumping ahead in the replay. Not the increment that it moves forward in while playing in replay. see here, This section of the Replay Window is used to jump forward or backward in time. There are different methods available for the amount to jump by along with the quantity associated with the movement.
https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#Jump |
