Date/Time: Sat, 18 May 2024 17:04:14 +0000
[Programming Help] - trading system based on 2 signals
View Count: 1035
[2021-03-11 09:08:24] |
User907968 - Posts: 804 |
you can see here (attached) that the signal (red down arrow) has no value
any other suggestion? You need to use the 'Chart Values for Tools' window, called 'Tool Values Window' in the menu. In your screenshot you are using the 'Chart Values Window', which reference the last bar displayed in the chart, not where the crosshair is - i.e. what's shown in you screenshot is not the data pertaining to the correct bar. If the arrow is drawn on the chart by a subgraph, then it will certainly have a value. |
[2021-03-11 09:13:02] |
User61576 - Posts: 418 |
i got it now, you are correct, the value is for the last bar on the chart. there is a value but its the price so if it's bigger than 0 then I can catch it thanks! |
