Date/Time: Sat, 31 Oct 2026 07:18:43 +0000
[User Discussion] - New rules regarding payment
View Count: 834
| [2021-03-09 10:03:06] |
| User266447 - Posts: 280 |
Dear Sir or Madam, From April I will need pay to directly to Sierra for charting package. How can I make sure I have enough funds in my account in order to pay $36 for April? Thank you in advance. Kind regards, Arek |
| [2021-03-09 17:09:07] |
| John - SC Support - Posts: 48377 |
You can add funds to your account on this page: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit You can see your account status from the Control Panel at the following link (just login with your Sierra Chart Account Name and Password, if not already logged in): https://www.sierrachart.com/UserControlPanel.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-10 19:25:22] |
Follow the instructions here: Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-10 19:30:20
| [2021-04-01 10:47:49] |
I was paying for Sierra Chart, version 5 - $26 per month via AMP futures. How much will I pay at Sierra for using version 5? (monthly payments) Thank you in advance, Arek |
| [2021-04-01 12:35:28] |
| Mr.Arsov - Posts: 16 |
This super easy to find page has the information you need Description of Service Packages and Pricing Do some searching on these simple questions before posting on the support board. |
