Date/Time: Sat, 10 Oct 2026 12:20:34 +0000
Trial with OneUp Trader
View Count: 1679
| [2021-02-24 19:16:43] |
| User410635 - Posts: 1 |
Is it possible to use the trial version of Sierra Charts with a prop firm like OneUp Trader that uses Rithmic?
| [2021-02-24 20:00:53] |
| John - SC Support - Posts: 48169 |
The Trial version of Sierra Chart is completely functional and does not have any restrictions. Therefore, it is possible to use for a prop firm. Just be aware that we do not offer any technical support for Rithmic issues. You will need to update the Bridge files in order to connect to Rithmic from Sierra Chart. You will find the files and instructions here: Rithmic Bridge Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
