Date/Time: Wed, 04 Nov 2026 14:21:32 +0000
No data coming through on trial
View Count: 704
| [2021-02-18 11:21:10] |
| User419765 - Posts: 2 |
Good morning, I have followed all answers regarding a similar issue but none of the provided solutions worked for me. I am getting the following message: Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-02-18 06:18:33.490 * What am I doing wrong, please? Thank you in advance for your help |
| [2021-02-18 11:33:24] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
