Date/Time: Wed, 04 Nov 2026 14:21:32 +0000
Transparent Square Offset Left(Right) for Candlestick - Variable Size
View Count: 780
[2021-02-18 11:17:20]
User16876 - Posts: 16
Would it be possible to add a "Variable Size" version of Draw Styles below keeping the size in Array[0] the same way like "Circle Hollow Variable Size, etc." does? Or at least to some of them (Transparent Square Offset Left/Right for Candlestick for example).
DRAW STYLES:
Square Offset Left
Square Offset Right
Square Offset Left for Candlestick
Square Offset Right for Candlestick
Transparent Square Offset Left for Candlestick
Transparent Square Offset Right for Candlestick
Triangle Right Offset
Triangle Left Offset
Triangle Right Offset for Candlestick
Triangle Left Offset for Candlestick
[2021-02-18 12:25:38]
Ackin - Posts: 1865
+1
