Date/Time: Wed, 04 Nov 2026 14:21:28 +0000
No available Liffe/FTSE100 exchange connection through TT
View Count: 924
[2021-02-18 09:13:55]
Dirk van van Bladeren - Posts: 3
I have activated the Liffe/FTSE100 Exchange real-time data and it works. How do I connect through TT to my AMP Futures account? EUREX through TT works, Liffe/FTSE100 not yet. Do I have to arrange for something?
See attached file.
Thank You In Advance.
Date Time Of Last Edit: 2021-02-18 09:17:17
imageInkedInked55_LI.jpg / V - Attached On 2021-02-18 09:17:09 UTC - Size: 195.75 KB - 397 views
[2021-02-18 09:42:29]
We see the broker appears to be AMP. We are fairly sure they do not support order routing over TT to LIFFE. You would need to have your trading account switched to CQG instead.
Date Time Of Last Edit: 2021-02-18 09:42:56
[2021-02-18 15:49:20]
Thank you. Yes, I have asked AMP and at this moment they do not support order routing over TT to LIFFE. I want to keep the TT connection for EUREX, it works great.
What do you think? The best and easiest way to trade LIFFE over CQG (at the same time as EUREX over TT) is with a second Sierra Chart trading account and a second AMP account?
[2021-02-18 15:56:53]
Regarding this, you can still use your same Sierra Chart account and install another installation of Sierra Chart to use with CQG at the same time as the Sierra Chart Order Routing Service:
Using Multiple Data and Trading Services at the Same Time
Whether you need a second AMP account or not we do not know.
