Date/Time: Wed, 04 Nov 2026 14:21:29 +0000
Time Scale still showing 0 (ver 2229)
View Count: 703
| [2021-02-17 22:13:13] |
| jackbravo - Posts: 73 |
Hi, I had some issues with the time scale showing 0 (which causes indicators such as initial balance and vwap not to work). I updated to the latest version 2229, and still showing the same issue. However, it's only happening on my Renko chart. It is not happening on my time based charts, including 5min, 15min, and 1hr. I am running similar indicators on both charts (Renko and 5min). Thank you. |
| [2021-02-17 22:42:04] |
| John - SC Support - Posts: 48413 |
There is a problem with one of your non-Sierra Chart studies. You would need to remove them one at a time and reload your chart to see which one is causing the issue (it could be multiple of them, so keep that in mind). You would then need to update the study or get the person that developed it, to update it for the new Date/Time class. Refer to the notes for release 2156 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php&p=1#SCVer2156 Most developers have already done this, so if you are working with someone that sells to multiple people, chances are that it is done and you just have to get the updated files. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
