Date/Time: Wed, 04 Nov 2026 14:34:49 +0000
Vol Delta number link with Vol Multiplier so both stay same? Pics..
View Count: 804
[2021-02-15 14:24:23]
HeyUgly - Posts: 287
Hello
I constantly have to adjust my Vol Multiplier {f5 chart settings} when using my numberbars charts to get the imbalance im looking for, i also use a vol delta on the side which gives me the delta of each level.
When i change my vol at price, i have to also change the vol delta ticks so they always match.
is there anyway to have them linked so i only have to change 1?
pics attached
image1.PNG / V - Attached On 2021-02-15 14:23:55 UTC - Size: 95.48 KB - 317 views
image2.PNG / V - Attached On 2021-02-15 14:24:06 UTC - Size: 48.92 KB - 310 views
[2021-02-15 14:29:03]
sometimes , the odd time it will trigger and will match when i change it but most times it doesnt. here is a pic that shows it not lining up where i have to go in and change it manually.
imagezero.png / V - Attached On 2021-02-15 14:28:59 UTC - Size: 8.51 KB - 345 views
[2021-02-15 14:30:23]
what ive found is if i change the vol multiplier going up , ie 5-10 or from 10-20, it will follow but if im going in reverse, it will not follow the change
