Date/Time: Wed, 04 Nov 2026 14:34:34 +0000
Daily OHLC study
View Count: 856
[2021-02-09 16:28:37]
User327844 - Posts: 5
In my OHLC study, everything appears except for the High, all have the same setting, any suggestion on how I may fix this?
[2021-02-09 18:31:39]
Most likely the other lines are above or below the visible area. Adjust your scale to see if you can find the other lines.
[2021-02-15 23:15:52]
That did not work, it may be the data feed? Because it works some days and some others it does not.
[2021-02-16 02:21:41]
Update Sierra Chart to the current version.
Instructions:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
