Date/Time: Wed, 04 Nov 2026 14:56:38 +0000
MARKET DEPTH HISTORICAL GRAPH STUDY SETTINGS ADDITION
View Count: 772
[2021-02-06 12:55:03]
User9890731 - Posts: 47
HI, I would like to know if support could add a feature to '' market depth historical graph'' specifically the ''determine min and max levels from all or visible bars'' settings..
the problem I have is that with the ''visible bar'' setting every time I scroll the colors from preceding bars affect the current depth colors and some tend to disappear if they encounter a historical depth that is bigger in volume than the current bars.
With the ''all bars'' setting selected literally most of the depth colors are not visible because there is a historical depth that was significantly larger in size than most...
So I am facing problems with both features because historical data is affecting the display of current depth data,
can there be a feature added to only display depth colors based on current bar not combined historical ''visible or all bars'', that way any data generated from the current bar remains as part of the historical data and it does not affect the next bar that follows.
so even if there is a bar with significantly high depth it will not affect the display of bars that follow regardless of size relative to it.
