Date/Time: Wed, 04 Nov 2026 15:07:13 +0000
More Custom Bar Periods
View Count: 1131
| [2021-02-02 16:27:25] |
| Botan626 - Posts: 294 |
Dear SC team, Please add more custom bar periods for control bar customization. Custom intraday bar period button can be added to control bar only 20 times currently, while there are 150 custom drawing tools. I'm using range bars for my analysis, and 20 range bar buttons is not enough even close for me. Could you make a total number of at least 50, please? Also, could you make 'Customize Control Bar' window resizable, or just increase its size? It is so narrow, hard to read info, especially in the available and selected commands sub-windows. Date Time Of Last Edit: 2021-02-02 16:29:03
| [2021-02-03 15:25:27] |
We will work on these.
