Date/Time: Wed, 04 Nov 2026 15:07:09 +0000
Conversion issues /float/int and int/float
View Count: 1199
[2021-02-01 17:33:27]
User92573 - Posts: 622
Dear Support
Thank you for answering the earlier request and my apologies for taking more of your time.
My programming in ASCIL is certainly getting a lot better but there are a few things I still struggle with. I'm sure it's pretty simple but your assistance would be a great help.
Simple example:
SCSubgraphRef updatedMovingAverageLength = sc.Subgraph[3] // this array holds the updated moving average length 'but its a float"
SCInputRef input_MovingAverageLength = sc.Input[0]
if(sc.SetDefaults)
input_MovingAverageLength .Name = "Simple Moving Average";
input_MovingAverageLength .SetInt(10); // this is the default moving average length
return;
// Do Calculations
if (something)
updatedMovingAverageLength[sc.Index] = input_MovingAverageLength.GetInt() + 5; // obviously 5.0f is incorrect also as I'm still mixing int and float values.
The issue is the the length is an integer (as usual); this is incremented by an integer ... but I'm having to store it in a float array. I do need array values not a Persistent Variable.
How do I store it in the correct array type?
... or do I have to convert it back and forth from integer and float values each time before use? I expect there is a specific array type but I've tried data and could not achieve the outcome either?
I know support doesn't help with programming but if you can provide some help/pointer it would be really helpful.
Thank you
