Date/Time: Wed, 04 Nov 2026 15:07:07 +0000
denali not working
View Count: 925
[2021-02-01 15:36:12]
CAACAP - Posts: 51
I just signed up for Denali and cme data but found out that i have to verify my non professional status which i cant do because i currently trade using tradovate and rithmic paper servers(topstep, oneup,etc) am i able to downgrade my package to the plan without denali for a credit?
[2021-02-01 17:12:47]
John - SC Support - Posts: 48415
First, you will want to deactivate the select exchange(s) for the Denali Exchange Data Feed. You can do this from this page:
Note that we cannot refund the Exchange Fees.
Next to change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
