Date/Time: Sun, 20 Sep 2026 00:57:14 +0000
Transact
View Count: 850
| [2021-01-25 15:34:26] |
| conr - Posts: 204 |
Hello. I saw your post regarding Transact. The only thing I use them for is to have a funded account. Do everything else through you. Am I going to be required to close that account and fund through another broker? Thank you. |
| [2021-01-25 19:51:01] |
Yes eventually but this is still a ways off.
| [2021-01-26 01:48:04] |
| User90125 - Posts: 715 |
It is interesting to note that many users do this. Or they keep the payments to SC directly debited from their broker so they don't have to think about it every month. Either way, the knee-jerk reaction to a common business move (consolidation) probably wasn't the best way to handle it. Hopefully SC will keep its connection to Transact/Infinity active until at least the end of 2021, given its renewed discussions directly with NinjaTrader. Just my two cents. Thanks. |
| [2021-01-27 05:25:40] |
Or they keep the payments to SC directly debited from their broker so they don't have to think about it every month. Automatic payments from a debit/credit card are being released at the end of this month, January 2021.Hopefully SC will keep its connection to Transact/Infinity active until at least the end of 2021, given its renewed discussions directly with NinjaTrader. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
