Date/Time: Sun, 20 Sep 2026 00:57:05 +0000
Trade Activity Log Displaying 'No Fills'
View Count: 954
| [2021-01-25 03:50:47] |
| user_xyz - Posts: 520 |
Why is Chart Stats showing a data line for 3 symbols that say 'No Fills'? I've exported my entire Trade Activity Log searched and those three symbols (YM, RB, BTC) are not in there, and the symbols are not in the drop down Symbol Selection window. I'm trying to remove them but they are not in the Trade Activity Log to do so... See attached screenshot |
| [2021-01-25 04:05:47] |
If you are trying to remove them, and they are not there, then what more do you want to do? We are not understanding this.
| [2021-01-25 05:06:18] |
I'm trying to understand where the data is coming from so I can clean up the Chart Stats report that is showing data that shouldn't be there. The manual says The data displayed on the Trade Statistics for Charts tab is calculated from the order fills for the particular Symbol and Trade Account the stats are for, which are available in the Trade >> Trade Activity Log yet I have no order fills for those symbols.So it seems like the data is coming from another log file, chart file or maybe there is a bug? I have ~6-10 other identical charts in the same chartbook with different symbols and yet those aren't showing up... Thanks, Chris Date Time Of Last Edit: 2021-01-25 05:07:32
| [2021-01-25 05:13:58] |
We are still not understanding this. so I can clean up the Chart Stats report that is showing data that shouldn't be there What data there are you referring to specifically?We understand that you are referring to the Trade Statistics for Charts tab of the Trade Activity Log but we are just not understanding what you are seeing there that is not right. And there is no other source of that data displayed there other than the Trade Activity Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-25 11:30:52
| [2021-01-27 03:49:55] |
Sorry trying to make this clear and I've spent the last few days diving into this... In the SC manual highlighted in green The data displayed on the Trade Statistics for Charts tab is calculated from the order fills for the particular Symbol and Trade Account the stats are for, which are available in the Trade >> Trade Activity Log.
This led me to think only charts with order fills would appear & show data. Yet in my case I have ~25 charts, ~5 I actively trade (show up in Chart Stats), the ~3 charts in question --> YM, RB, BTC (screenshot) show 'No Fill', the remaining 17 remaining charts don't show up at all (as I believe they shouldn't because there are no order fills). My confusion is why are YM, RB, BTC charts showing 'no fill' and the other 17 are not? I found toggling Trade --> Show Orders & Positions will lead to the chart showing up in Chart Stats and displaying 'No Fill' even though there are no order fills. So in my case YM, RB, BTC had 'Show Orders & Positions' checked while the other charts were unchecked. Ok problem solved, just confusing in the manual. It would be nice to have a Chart --> 'Display in Charts Stats' option. Example I have 'Show Orders & Positions' with many charts (Historical, TPO, Weekly, 5 Min, Trade MBO, etc) Chart Stats then has the same symbol represented 5 times... Thanks! Date Time Of Last Edit: 2021-01-27 03:51:25
