Date/Time: Wed, 04 Nov 2026 15:41:23 +0000
custom Chartbook will not load
View Count: 851
[2021-01-20 18:43:31]
User579167 - Posts: 1
I am having trouble loading a custom Chartbook.
I get multiple messages on the message log such as the below.
Unsubscribed from market depth data for ZNH21_FUT_CBOT | 2021-01-20 18:37:19.764
Unsubscribed from market depth data for ESH21_FUT_CME | 2021-01-20 18:37:19.764
Unsubscribed from market depth data for CLG21_FUT_NYMEX | 2021-01-20 18:37:19.764
Unsubscribed from market depth data for 6BH21_FUT_CME | 2021-01-20 18:37:19.764
Unsubscribed from market depth data for 6EH21_FUT_CME | 2021-01-20 18:37:19.764
Chart (ESH21_FUT_CME) | Encountered unknown Chartbook Field. Field Code: 542. Previous Field Code: 541 | 2021-01-20 18:37:36.774 *
File compression not supported on file system. \\Mac\Home\Desktop\Data\ESH21_FUT_CME.scid. Windows error code 1: Incorrect function. | 2021-01-20 18:37:36.858
ESH21_FUT_CME #37 | Reloading chart. | 2021-01-20 18:37:36.868
File compression not supported on file system. \\Mac\Home\Desktop\Data\ESH21_FUT_CME.scid. Windows error code 1: Incorrect function. | 2021-01-20 18:37:36.890
File compression not supported on file system. \\Mac\Home\Desktop\Data\ESH21_FUT_CME.scid. Windows error code 1: Incorrect function. | 2021-01-20 18:37:36.917
Chart (6BH21_FUT_CME) | Encountered unknown Chartbook Field. Field Code: 542. Previous Field Code: 541 | 2021-01-20 18:37:36.946 *
Please can someone assist?
[2021-01-20 19:22:30]
John - SC Support - Posts: 48419
The first thing to do is to select Edit >> Translate Symbols to Current Service after you open that Chartbook. Those symbols are for the Sierra Chart Order Routing Service, which you are not using.
After you translate the symbols, then see if you continue to have issues.
Date Time Of Last Edit: 2021-01-20 23:35:59
