Date/Time: Wed, 04 Nov 2026 15:40:13 +0000
Chart Header Removing Lock / Account information
View Count: 964
| [2021-01-20 13:27:51] |
| ycomp - Posts: 334 |
I would like my chart to not display the Account / Lock status... I have attached what my global header settings are... and the ES chartbook displays as defined in those settings. The NG chart in the NG chartbook does not. Is there some local settings in a chart / chartbook that override the global ones? Please point out where to find them, thanks. |
Attachment Deleted. |
| [2021-01-20 14:36:16] |
Where are you seeing this shown on the chart?: I would like my chart to not display the Account / Lock status.
You might want to disable Chart Trade Mode: Trade Menu: Chart Trade Mode On (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-20 14:38:46
| [2021-01-20 14:42:53] |
ah thanks that was it
