Date/Time: Wed, 04 Nov 2026 15:40:14 +0000
Two different SC account with one platform
View Count: 936
| [2021-01-20 02:22:24] |
| User486198 - Posts: 1 |
Hello, I have two account (primary and sub-account) created by AMP futures with sierra chart subscription. My question is, is there a possibility to connect them together so I don't have to buy denali data feed for the sub-account and use two different sierra instance? I'm trading now from this account through futures order routing service and I'd like to use it with my sub-account too. From AMP I didn't get any information how is it works, they told me I have to setup a complete new sierra subscription with data service and use my login with new instance. As I know there is an option in trade window where I can choose the account I want to send the orders to. Is there any other option to use two different broker account within one sierra instance? If yes, how can it be done with AMP accounts? Thanks for your answer! Best regards, |
| [2021-01-20 14:31:45] |
Yes this is fully supported. You definitely do not need a separate Sierra Chart account. Could you please complete this form for the other account: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm You then would select the second account as you described from the Trade Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-20 14:31:53
