Date/Time: Wed, 04 Nov 2026 15:41:09 +0000
127451
View Count: 806
| [2021-01-19 16:05:22] |
| User440587 - Posts: 4 |
In SIM environment trades are not being reported on the trade activity reports. Trades are displayed on charts.
| [2021-01-19 16:16:18] |
| John - SC Support - Posts: 48419 |
Follow through the information at the following link to make sure everything is set properly to see the information: Trade Activity Log: Viewing Historical Trade Activity For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-19 17:06:50] |
All settings of the trade activity log were as specified in this thread except that Simplebracket.twc was selected instead of All Notes. Is it likely that this could have caused some trades not to be recorded on the log although they were displayed on the charts?
| [2021-01-19 17:13:22] |
Having a specific Note and filtering on that field would definitely only show those trades that had the Note set to that value. So you have all the filters set to the "All" options and you have selected Apply? And the date range is set to include the dates on which your trades occurred? And you are still not able to see the trades in the Trade Activity Log? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-19 18:18:11] |
I have now changed the filter to "All Notes" and will see if that fixes the problem or the problem persists.
