Date/Time: Wed, 04 Nov 2026 15:41:11 +0000
DOM not recentering on double click
View Count: 785
| [2021-01-19 15:08:29] |
| User475862 - Posts: 37 |
under the new release 2218 the dethatched DOM is not recentering on double click. it works if the DOM is attached to the main chart book. this was not an issue in previous releases. Thanks D |
| [2021-01-19 16:01:47] |
Update to the latest prerelease following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
