Date/Time: Wed, 04 Nov 2026 15:39:57 +0000
Number bars - Delta with threashold not coloring properly
View Count: 764
| [2021-01-19 00:53:50] |
| User837393 - Posts: 161 |
Hello, I'm having a weird issue that when using numbers bars with the following setup : Column 1 Number Bar Text : AskVol BidVol Difference Column 1 Background Type : ASk Bid Difference Profile Column 1 Background Coloring Method : Based on Diagonal AskVol BidVol Difference -Actual Column 1 Text Coloring Method : None Some of the difference profile colors are not showing up they show in black and not in green or red (see pictures and arrows), where number 65 should be receiving a green color profile and -126 should be receiving a red color profile. Can you assist in what the issue is. Note : The coloring setup for Column 1 is all set by default. See picture. http://www.sierrachart.com/image.php?Image=1611017837927.png Date Time Of Last Edit: 2021-01-19 00:58:57
| [2021-01-19 14:35:37] |
| John - SC Support - Posts: 48419 |
Please attach a chartbook that has just that chart in it for us to take a look and see. Follow these instructions for how to get and post the chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
