Date/Time: Wed, 04 Nov 2026 15:41:25 +0000
Query on Replay
View Count: 931
| [2021-01-18 20:19:56] |
| User99735 - Posts: 234 |
Hi, In Replay, with - Charts to Relay set to "All Charts in Chartbook" - Replay Mode set to "Calculate at Every Tick/Trade (High CPU)" What is the significance of value entered in "Enter Processing Step in Second" popup, as the processing / replay mode is set to every tick? Regards Vivek |
| [2021-01-18 22:58:33] |
The processing step controls the amount of data processed for a chart before calculating the next chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-18 22:58:56
| [2021-01-19 03:06:43] |
Hmmm, would sc.GetChartBaseData() fetch the latest tick by tick data from the 'next chart' with Replay Mode set to "Calculate at Every Tick/Trade (High CPU)", irrespective of the the setting of 'processing step' In replay with the following indicators/settings on the 'main' chart a) Volume By Profile indicator attached to the chart where replay is being run, along with calls to sc.GetStudyPeakValleyLine(), and b) calls to sc.GetMarketDepthBars() for market depth ask/bid volumes, alongwith the following settings, seems to cause some 'mess up'. sc.MaintainVolumeAtPriceData = 1; sc.MaintainHistoricalMarketDepthData = 1; sc.UsesMarketDepthData = 1; Any suggestions. |
| [2021-01-19 03:16:37] |
seems to cause some 'mess up'. We have no idea what you are referring to and this is fully outside the scope of our support. We cannot possibly get involved with what you are doing. We cannot respond further to this.Regarding this function: would sc.GetChartBaseData()
when you are getting data for another chart, that chart during a replay will not have the data which is up to date to the time of the chart containing the study making the function call. There is no way around this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
