Date/Time: Sun, 20 Sep 2026 05:27:29 +0000
include F.US.TWN SGX FTSE Taiwan Index Futures
View Count: 1048
| [2021-01-14 18:54:56] |
| Chap - Posts: 39 |
Hi. Could you include this market: F.US.TWN. SGX FTSE Taiwan Index Futures in the list of symbols. Thanks. |
| [2026-07-28 09:42:08] |
| b1u3lee - Posts: 25 |
Hi Does Sierra support the FTSE Taiwan Index Futures? |
| [2026-07-28 13:23:06] |
| John - SC Support - Posts: 47939 |
We do not have this data ourselves. If you are using CQG for your order routing, then you might be able to get the data from them - you would need to check if it is available from them, then you would enter the appropriate symbol in the "Selected Symbol" field on the "Find Symbol" window. Or, if you just want to chart the data and not trade directly, then you could see if you can get the data from DTN IQ Feed, with which we have compatibility. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
