Date/Time: Wed, 04 Nov 2026 15:41:10 +0000
Spreadsheet autoTrading questions
View Count: 922
| [2021-01-14 16:29:58] |
| User230002 - Posts: 1 |
I am using spreadsheet auto trading. Seems to be working fine with some behavior I can't explain. Running live, not sim. 1: Currently trade one contract ES, One chart. Have "Maximum position allowed" set to 1. Have the attached trade window qty set to 1. Spreadsheet J26 set to "Order qty" of 1. Trades this 1 contract fine. When I change all qty's to 2, it continues to trade 1 contract. What am I missing? 2: I noticed on the spread sheet, that row cells J3 thru J11 are not updating(all 0). Not sure if that is connected somehow,or that is a different issue? Thanks, data feed: Denali Broker: Amp Date Time Of Last Edit: 2021-01-14 21:10:37
| [2021-01-15 10:26:09] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
| [2021-01-15 10:36:36] |
| User165160 - Posts: 23 |
This step is done, I'm now logged in to correct account.
| [2021-01-18 22:28:49] |
Should I repost this question?
| [2021-01-19 04:43:17] |
When I change all qty's to 2, it continues to trade 1 contract. What am I missing? You just need to set the quantity on the spreadsheet:Spreadsheet Systems, Alerts and Automated Trading: Order Quantity (read / write) [v1:J26, v2:J69] And make sure you are setting it on the correct Sheet. It needs to be the sheet controlled through this study Input: Spreadsheet Study Inputs: Chart Data Output Sheet Number 2. This is probably related to the above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-19 23:39:28] |
got it, thank-you.
