Date/Time: Thu, 19 Nov 2026 17:10:18 +0000
DAX and STOXX indexes - adding to feed request
View Count: 1464
| [2021-01-13 14:55:08] |
| User365411 - Posts: 196 |
Please can you add Dax, Euro Stoxx 50 and Stoxx Europe 600 index? (not futures) EOD is enough, better if there are intraday data too, realtime is not needed. CFD from FCXM are not good. Found that Barchart have these data https://www.barchart.com/stocks/quotes/$DAX https://www.barchart.com/stocks/quotes/$STXE except Stoxx Europe 600 index, maybe they have it too. TY |
| [2021-01-13 17:06:58] |
We will add these.
| [2022-01-21 18:31:14] |
| User609134 - Posts: 14 |
Hi, I have posted a similar query to that of the original question above. Please can you tell me where I can activate the $DAX and $STXE feeds? I need this data for my software as stated in my previous support ticket. Cheers |
| [2022-01-21 18:53:37] |
We only have the futures prices for the DAX. What is $STXE? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-21 19:07:27] |
Hi, $STXE and $DAX are both listed under ‘Indexes-Other’. $STXE is Euro Stoxx 50. I am subscribed to the Eurex feed and receive Dax futures data, but I would like to receive Dax index data similar to that of $DOWI and $INX (S&P Index). Cash data on FXCM is an okay reference but I would prefer to use a Dax data feed similar to that offered via $DOWI and $INX. Cheers |
| [2022-01-22 04:23:00] |
No there is not any real time or Intraday data available for those symbols.
