Date/Time: Wed, 04 Nov 2026 15:53:05 +0000
Compiled SC .dll give virus error
View Count: 1009
[2021-01-12 22:52:24]
ertrader - Posts: 698
Hi Support...after compiling my own .cpp code, uploading to google drive, then downloading, I get the following error stating the file has a virus. I use the remote compiler, only SC .cpp code (no external calls). Can you please help? Is this a false error? Attached is the error message and .dll however it happens with any file I compile with SC remote compiler.
Date Time Of Last Edit: 2021-01-12 22:53:17
imageScreenshot from 2021-01-12 17-46-20.png / V - Attached On 2021-01-12 22:49:41 UTC - Size: 14.22 KB - 367 views
Private File
[2021-01-12 23:14:19]
Certainly it is a false error because obviously the code does not contain anything malicious.
So you just need to ignore it.
