Date/Time: Wed, 04 Nov 2026 15:52:55 +0000
MARKERT PROFILE DISTORTED/NOT VISIBLE
View Count: 943
[2021-01-12 15:12:05]
User383305 - Posts: 3
HELLO GUY, I TRIED TO LOAD A MARKET PROFILE FOR EURUSD, FOR PERIOD OF 365 DAYS BUT SOON AS IT FINISHES IT LOAD A SERIES OF VERTICAL BARS WHICH DOESNT MAKE SENCE, I HAVE ATTACKED SCREENSHOT, PLEASE ASSIST ME GUYS.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=46997
[2021-01-12 18:46:11]
John - SC Support - Posts: 48419
Please attach the Chartbook with just that chart in it following these instructions:
[2021-01-12 19:10:13]
HEEY, I HAVE ATTACHED A CHARTBOOK AS YOU REQUESTED, YOU CAN SEE FROM THIS A GBPUSD MARKET PROFILE BLOCK IS DISTORTED
attachmentFOR SUPPORT Chartbook1.Cht - Attached On 2021-01-12 19:07:50 UTC - Size: 6.18 KB - 441 views
[2021-01-12 19:36:02]
We are not seeing any issue when we open the chart, apart from the scaling of the chart. Make sure your scale is set to Automatic and see if that resolves your issue. Refer to the following:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
[2021-01-13 18:00:10]
Based on the screenshot you originally posted, the Chart Settings are not correct. Follow the instructions here to correct the relevant settings:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
And then set this TPO Profile Chart study Input to 5 or a number that gives you a reasonable display:
Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks
Date Time Of Last Edit: 2021-01-13 18:00:33
