Date/Time: Wed, 04 Nov 2026 15:52:52 +0000
Server side, attached order
View Count: 1097
| [2021-01-12 10:22:42] |
| BenjFlame - Posts: 353 |
Hello, I'm on Denali feed and TT order system, so I guess my setup fully supports server side orders. In Trade >> General Trade settings I enabled OCO and Bracket server side orders if supported. When I place a real trade, I use a single attached order (stop loss) so it is neither an OCO or Bracket. I'm not sure in this specific case of only a single order attached, if it is sent to server or not. How can I verify this? |
| [2021-01-12 16:10:01] |
In this case, the single order will not be sent to the server until the parent order fills. You need both a Target and Stop order. You still need to use the Target order but put it at a far away price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-12 16:10:30
